RV.Net Open Roads Forum: Travel Trailers: Scissor Jacks -- Install Mid Rig
 > Scissor Jacks -- Install Mid Rig
JAL_Camper
Raleigh, NC
Posted: 06/02/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Looking for advice on where to install newly acquired scissor jacks
My thoughts now are to go with curb side just forward of wheels and street side just behind -- due to sewer outlet in the way on that side. Midpoint of TT (excluding tongue) is just ahead of tires, so that's why I want them there, even though only curb side can be located there (and as close to tires as I can get.) Any problems with installing them this way?
Just going to use them to firm up the middle section to eliminate the bounce caused by the suspension. Camped two weekends ago, and as an experiment, I used two car scissors jacks on either side near the wheels, and the difference in was significant. Bolted on scissors should should be an even better improvement.
I realize there are better products out there, etc. but I got a deal on these jacks and looks like an easy install (they are same as corner jacks.)
Any thoughts/advice is greatly appreciated!
JAL
2002 Burb 2500 LT, 8.1L, Autoride, 4x4
2005 Jayco Eagle 298BHS
Check It OutReese HP 1,200 Lb. Bars WD/Dual Cam HP Sway Control/Prodigy® Brake Control
Family: Two Baby Boomers with Two Generation Y Kids -- All RV Generation
CAMPED IN:
cmartin7143
ILL
Posted: 06/02/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
We had mid levelers installed in front of both wheels and it works nice. can see no problem with your idea as long as you don't try and lift TT. why not just mount behind should still work as they just take the spring out of the springs? good luck.
byrdr1
Elon, NC / Central Piedmont
Posted: 06/02/08 09:32am Link  |  Quote  |  Print  |  Notify Moderator
JAL,
I have a friend who has done this and he mounted both jacks in front of the tires as close as he could. Works like a charm.. with 6 scissor jacks his camper is very firm when walking around in it..
I have bounced around in it just to see.
randy
Go #8 Mark Martin
2003 F-350 SRW CC/LWB 4X4 7.3PSD
2005 Keystone Cougar 301BHS 8400lbs Ready to Camp CAT scale Certified
My Webshots Pages
Happy Campin'
Randy
Elon, NC-Piedmont area
bldrbuck
Boulder, Colorado
Posted: 06/02/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
It should work if you can get even pressure on all six jacks. Personally I perfer Rotochoks.
spepi
Mansfield MA
Posted: 06/02/08 11:22am Link  |  Quote  |  Print  |  Notify Moderator
I installed these in front of my tires...what a difference...still get some bounce, but nothing like before...I used self tapping screws, and installed them with my 18volt DeWalt in about 10 minutes...didnt have to pre drill any holes. I have an I frame on my TT
DW, 2 Teen's, 2 Dogs
05 Chevy Trailblazer (I know...its small)
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Contol
2008 Rockwood 2701ss
Camping Hoosiers
Southern Indiana
Posted: 06/02/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
We had room in front of our wheels so we mounted them there which is close to the center of the trailer. These do work well to eliminate some suspension bounce on long trailers. We have done this on our last two trailers.
2006 Jayco Eagle 314 BHDS
2003 Suburban K2500 LT 8.1 V8
KYANNA BIRDS - Jayco Flight # 14
JAL_Camper
Raleigh, NC
Posted: 06/02/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much for everyone's comments! I realize they are for stabilizing and not lifiting. I do side to side with beveled boards of various thicknesses and dowels to keep in place and do front to back with tongue jack. The jacks go down last and just firm up the config.
My TT frame is "I" beam, also. Scissors will be attached like ones in corner from the factory. Looks easy.
Just wanted to run it by you good folks here if I was missing something or if someone had a better idea on install location.
Thanks, again.
DavidG
near Seattle, Washington, USA
Posted: 06/02/08 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
JAL,
Put the jacks where the instructions suggest...one on each side in the front and in the rear (4 total). Here is my write-up on the topic.
David and Laura G
Click here for RV Towing Tips and more
2003 Suburban K2500LT 4WD, 8.1L, 3.73, Autoride 14-16 mpg hwy, 10-12 city, 8 towing
2008 Adirondack 31RL
Prodigy brake controller, Surge Guard
havedreamwilltravel
Posted: 06/02/08 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
DavidG wrote:
JAL,
He already has those - I think he's talking about adding 2 more scissor jacks in the middle of the trailer to give more "support" and to eliminate the bounce you get from having a long trailer.
I've thought of doing the same on ours. I think it's a great idea.
Great! One more mod to add to the growing list I already can't seem to get to!
2007 GMC Yukon Denali - 6.2L 380hp/417ft-lbs,0-60 in 6.2 seconds
2007 Jayco Jayflight 27BH
Equalizer Hitch, Prodigy Brake Control
Our Truck and Trailer
Easy Trailer Mods-NEW pics added 4/10/08
Visited a lot of states, haven't camped in many...yet.
DavidG
Posted: 06/02/08 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Our last trailer was 28' with a scissor jack at each corner, and doing it the way I describe on my webpage, I had no bounce and no problems. So I don't see any need to add more jacks.
