RV.Net Open Roads Forum: Folding Trailers: Refrigerator fan help needed
 > Refrigerator fan help needed
hawk_fan
Medford, OR
Posted: 06/08/08 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
I'm about to install a 12V fan to cool the refrigerator fins. I was wondering where to splice the fan wires into. There is a white plastic sheath marked 120V and one gray plastic sheath marked 12V. I cut a slit on the one marked 12V and inside are two brown wires (not labeled). Is this where I splice into? If not, any suggestions where?
Pics would really help!
Thanks!
'08 Fleetwood Niagara
'07 Chevy Silverado 2500HD CC
Our Mods and Pics
mtkbuckeye
Clinton, Utah
Posted: 06/08/08 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
you know I had the same question but went ahead and wired mine up to one of those radio shack mono plugs and just plug it in to the outside light when we need it and it works absolutely great. I will go take some pictures right now.
2007 Fleetwood Arcadia
2006 Ram 1500 Quad Cab Hemi 5.7L
"If we ever forget that we're one nation under (the one we trust on our currency), then we will be a nation gone under." - Ronald Reagan
chkster
Antioch,Ca
Posted: 06/08/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
`IIRC the choice of wires on the 12V line will only switch the direction of the fan....
Welcome to California...now go home!
SIGMA NU
2005 GMC Sierra Ext. cab 5.3L 3.73
2004 Coachman Clipper Classic 1070ST
Chkster and Hapekampr A.K.A
Charles and Cheryl
:-D
mtkbuckeye
Clinton, Utah
Posted: 06/08/08 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Here are my pictures.
You will see my fan is mounted on the bottom and I just store the wire in the area there when we travel. Once set up and it is warm enough outside to run the fan all I do is plug it in and it goes. No switches or anything when it is plugged in it is on and it works great. I never use that plug anyway so I figure that was a good place for it and didn't have to splice into anything there. I like to leave things as they are myself as much as possible.
Hope this helps.
* This post was edited 06/12/08 12:00am by an administrator/moderator *
hawk_fan
Medford, OR
Posted: 06/08/08 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
mtkbuckeye, what size mono plug did you buy?
mtkbuckeye
Clinton, Utah
Posted: 06/08/08 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
This is the one.
Radio Shack plug
1/4" Mono Plug 2-pack
hawk_fan
Medford, OR
Posted: 06/09/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Anyone else with advice?
MattC
Missouri
Posted: 06/09/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I bought and use a regular a/c plug in fan I got from Radio Shack. We only camp with electric hook ups so that works for us. It won't help you if you boondock any though. I just plug it in in the refrig compartment with a splitter on the plug.
MattC from MO
2003 Grand Caravan
2008 Palomino Yearling 4102
Wife and 4 kids
Campingfools
Illinois
Posted: 06/11/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I used a wire tape to pull the 12V wires from the fan to the porch light and tied in there. There is room just under the back edge of the counter top to run the tape. On my fridge, I couldn't identify a 12V source. Anyway, fan works just fine, and the fridge stays cold enough to keep ice cream.
2006 Explorer EB V6 w/TP WDH (Picture is wishful)
2007 Fleetwood Niagara
sushidog
Abita Springs, LA
Posted: 06/11/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
In an evaporation type refrigerator, the difference in temperature between the evaporator coil and the condenser is what makes the refrigerant (basically ammonia) circulate.
This is why heat is applied to the evaporator side. Placing your cooling fan at the bottom is not nearly as efficient as placing it by the top coils.
Yes, it helps to keep the overall temp below 100 degrees in the back of the fridge, by keeping air circulating, but you would do better to have a fan exhausting warm air out the top vent.
That's how the OEM Dometic fan is configured. They should know, as they build the fridge.
This is how my set-up looks:
I replaced the single, noisy stock fan with a much quieter, high-tech, fluid bearing dual fans that together move more air than the single, original (112cfm vs 88CFM for the original fan).
They draw it across the entire condenser coil too, rather than just part of it. As a side benefit, together they use a little less current than the single, Dometic fan.
