RV.Net Open Roads Forum: Folding Trailers: Refrigerator fan help needed
 > Refrigerator fan help needed
signmonkey
West Palm Beach, Florida
Posted: 06/12/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a kit from Popuptimes.com and tapped my 12v for the
frig...
2006 Evo 2
2003 F150 4x4
2006 Suzuki 400 4x4
2006 Yamaha 350 4x2
mtkbuckeye
Clinton, Utah
Posted: 07/01/08 07:39am Link  |  Quote  |  Print  |  Notify Moderator
The beauty of my setup is I can go ahead and change it over to the top venting and without any problem as all I need to do to move the fan as it is not mounted anywhere that can't be changed.
I will try that next trip out. We just got back from 4 days at Flaming Gorge and the fridge worked like a charm. Kept our popsickles frozen all weekend long!!
2007 Fleetwood Arcadia
2006 Ram 1500 Quad Cab Hemi 5.7L
"If we ever forget that we're one nation under (the one we trust on our currency), then we will be a nation gone under." - Ronald Reagan
mtkbuckeye
Clinton, Utah
Posted: 07/01/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
signmonkey....
That is the same exact fan as I have and it works great!
pete42
Jamestown, Ohio
Posted: 07/02/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
hawk_fan wrote:
I'm about to install a 12V fan.
a white plastic sheath marked 120V
one gray plastic sheath marked 12V. I cut a slit on the one marked 12V and inside are two brown wires (not labeled). Is this where I splice into?
Thanks!
12 volt fan needs 12 volts to work so use the 12 volt wires.
hook the wires to the "brown" wires to see which way the fan runs if it "blows" then you have it hooked correctly.
If fan runs backwards reverse the wires.
Hook one wire to the fan wire with a splice or solder joint cover with tape.
add an inline fuse radio shack and a toggle switch to the other wire place toggle switch inside of trailer if possible.
Or get real fancy and add a thermostat toggle switch and fuse.
feel free to PM me if I can help.
PETE
* This post was edited 07/03/08 11:12pm by pete42 *
pete42
Jamestown, Ohio
Posted: 07/02/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
frig...
nice install job is that a thermostat or a high temperature safety on the back of the fan?
jerr529
NY
Posted: 07/02/08 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.adventurerv.net/solar-fridgecool-fan-p-1252.html this is a solar fan conect from top of unit and free power
http://www.rvpartscenter.com/ProductDetail.asp?ProductID=31051&StoreID=11&DepartmentID=13&CategoryID
this is another place for one
jerry
* This post was edited 07/02/08 03:18pm by jerr529 *
23ss Roo 09
chevy 09 Silverado 5.3 V8 3.73
DW,4boys all grown, GC 5 boys 5 girls ages 8 down to 1
http://community.webshots.com/user/jerr7
Equalizer hitch
ultra fab 3500 Power Jack
highside
Big Sky Country
Posted: 07/03/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
The description on those sites make it sound like it should go in the refrigerator. Does it really matter if it goes on the inside or the outside?
Rob
He Ruide
Cincinnati Ohio
Posted: 07/03/08 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Rob, Those fans need to be on the outside to cool the fins and thus improve on the efficency of the fridge. Here is a fan that you could put inside the fridge.
Ruide
Fleetwood Evolution E3 - Yellow (DW let me get a Yellow one since she wanted an E3 with a slide out )
Hummer H2 - Black (DW vetoed the Yellow one, but I got two Yellow Hummer Folding Mountain bikes )
My Pics and Mods and My Weekly Blog
mike4947
N. Syracuse, NY
Posted: 07/03/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Nope they are external fans. Here's a link to the inside the fridge battery operated fan:
http://www.pplmotorhomes.com/parts/rv-refrigerators/rv-refrigerator-fan.htm
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
highside
Big Sky Country
Posted: 07/03/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
So the intent is to have a fan blowing across the exterior fins?
Am I to assume that even hot moving air is better than stagnant(sp) non moving air?
Rob
