RV.Net Open Roads Forum: Travel Trailers: Installing Stereo ??
 > Installing Stereo ??
SNC
Alberta
Posted: 06/18/08 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys, your input is much appreciated !!
I'll let you know how it goes !!
StuartW
Virginia
Posted: 07/02/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to consider installing a battery cutoff switch in the wire that feeds your DC breaker panel. This way when you leave the rig in storage you can shut down all of the small loads (like the radio memory, smoke detector, propane detector, etc.) that virtually ensure a dead battery if you don't use the rig for a while.
I installed a small 2" battery switch that I bought at West Marine and flush-mounted right next to the AC/DC panel. By mounting it here it's right next to the entry door so it's the first thing that I turn on when I enter the trailer and the last thing I turn off when I leave it. By mounting it here it also doesn't interfere with the operation of the emergency breakaway circuit or battery charging while towing ...
Good luck!
StuartW
2004.5 Dodge Ram 3500 Laramie
CTD HO 4x4 SRW LWB QC / Leer 100XQ cap
2005 HR Savoy SL 26RKS
dodge guy
Chicago, western subs.
Posted: 07/02/08 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, turning off the radio will be the same as turning off the ign sw. in a car. I did the same thing with mine and left it for a month and the battery was no more low than with the old factory radio.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
