RV.Net Open Roads Forum: Travel Trailers: Scooter carrier on back of trailer
 > Scooter carrier on back of trailer
qwerty11
Posted: 06/26/08 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have a scooter (motor kind) carrier that fits into a 2"hitch. Scooter and carrier probably weigh around 300 lbs. My unloaded hitch weight is 330 lbs. I'm thining I probably put around 50-100 lbs of additional stuff in the front storage compartment. I am wanting to mount the scooter carrier on the back of the trailer.
Is there a hitch made for the back of the trailer?
Can the trailer support the weight?
Will the tongue be too light?
Any ideas how to do this?
bldrbuck
Boulder, Colorado
Posted: 06/27/08 03:43am Link  |  Quote  |  Print  |  Notify Moderator
qwerty11 wrote:
Is there a hitch made for the back of the trailer? Any good weld shop or RV service should be able to install one.
Can the trailer support the weight? Yes but your tongue weight already sounds to be low. Maybe the front of the tow vehicle is a better place.
Will the tongue be too light? I don't know you need to give us the total trailer weight. The tongue weight should be at least 10 - 12 per cent of that.
Any ideas how to do this? see above.
Dick_B
Palos Heights, IL USA
Posted: 06/27/08 06:07am Link  |  Quote  |  Print  |  Notify Moderator
In my uneducated opinion that is too much weight on the back of a TT because the tongue weight will be too light.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
NCHornet1
Mt. Airy, NC.
Posted: 06/27/08 07:31am Link  |  Quote  |  Print  |  Notify Moderator
You will need to compensate more than 50-100lbs in the front. You need to go weigh your trailer first. Get a tire weight and a tongue weight, every trailer is different so there isn't any way we can say yes or no, although many will. Can it be done correctly, sure, it is all in the weights. You want 10-12% of the total TT weight on the tongue. They make bolt on receivers for the rear bumper, although I wouldn't use them. Take it to a hitch shop and have them weld one in as well as supporting the rear frame work of the trailer.
Good luck
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
jauguston
Bellingham, WA
Posted: 06/27/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
You would be wise to discuss this with the trailer manufacturer. Most have barely enough frame to hold the box up let alone something hanging off of the back.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
ScottG
Bothell Wa.
Posted: 06/27/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
As someone who tore a welded bumper off the back of a TT with just three light bikes, I can tell you I'm doubtfull this is doable. The leverage and twisting action of something like that bouncing down the road is tremendous. At a minimum you need to get the bumper replaced with a thicker material and heavily reinforced by a good welder but as Dick B. suggested, you will likely have handling problems due to the lightened front end.
Best of luck,
Scott
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
JJBIRISH
Butler, PA, USA
Posted: 06/27/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
there is a universal hitch that is wide enough...
I don't think much of them though, for the same money one can be made...
in my humble opinion, NO...
I don't know much about your trailer but the longer it is the bigger the NOOO is... the lighter it is the bigger the NO...
you need to add the weight of the hitch to that 300 lbs to don't forget...
YES
but you need to weigh it to know how much to light... it would be difficult to load near 400# on the back of a trailer with 330# tongue weight and add enough in the trailer anywhere without overloading the axles...
not any that would work and be safe to pull...
call the trailer mfg or chassis mfg to find out how much weight the chassis will support back there...
do not rely on the dealer for this information...
if a welder says he can do it ask for a warranty, make sure the warranty covers the intended use and any resulting chassis damage...
I have had welders tell me they would guarantee their work, but all that means is the hitch won't break, and has nothing to do with the fitness of the hitch to do the intended job on the chassis it is welded to...
* This post was edited 06/27/08 03:10pm by JJBIRISH *
Love my mass produced, entry level, built by Lazy American Workers, Hornet
MFinCA
San Francisco Bay Area, CA
Posted: 06/27/08 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I looked into this issue to carry my Champion Generator. It won't fit in the TT, and I don't like carrying it in my 'Burb. The prevailing opinion (3 different hitch places) is that putting weight on the back of the TT is not a good idea.
So I put a 2" front receiver hitch on the 'Burb and have a tray that is rated at 500 lbs.
I'll carry it up there when I need to take it with me. If we ever get back into bicycling again, I'll buy a bike rack and carry them on the front of the 'Burb.
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
qwerty11
Posted: 06/29/08 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Well let me ask you this. I have plenty of extra carrying compacity on the trailer. Can I not just put the thing in the camper. I thought I could get some D-ridngs and bolt them to the cross braces on the frame.
JJBIRISH
Butler, PA, USA
Posted: 06/29/08 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
basically you can do anything you want, as long as proper balance and loading is maintained...
inside the load is primarily on the axles, and you will still need to insure you have proper tongue weight...
a TT stability is all based on balance, and is the most important part of safe towing...
