66bronco
Tucson
I live in Az and still camp with my family during the extreme summer heat. Does anyone have any recommendations on tents that may help make it more comfortable? I know it’s asking a lot of a product, but any little bit will help.
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Depending on the size of your tent, you may be able to install something like an EZ-Up awning over the top of it, in order to provide shade. EZ UP
Vapor_Trails
Yucaipa, CA
Nothing short of air conditioning in the tent will be comfortable when it's 110° during the day and 90+ at night.
68 Me & DW
93 DD
03 DD
06 F150 Screw 6.5' Bed, 4x4, 5.4, 3.73
04 Tahoe 23RB-GL
Honda EU2000 Parallel Cables
"I hope you like Guinness, Sir. I find it a refreshing substitute for...food." Col. Jack O'Neill, Stargate SG-1.
Kamper_Kelly
There are a couple of recent posts on this same subject. Try searching for things like A/C or keeping cool (or just scrolling down).
mikew9
a personal water misting bottle will drop air temps a remarkable amount in dry desert heat. You can probably find inexpensive plant misters at wally world and such. There are also units which also incorporate a small battery powered fan (e.g personal mister). Try a google search!
Cheers
Mike in Texas
dchuntnevada
Nevada
The EZ up idea helps a bit (trees are better), leave the rain fly off helps air flow. If you have a generator a swamp cooler blowing on you works. The swampy brand swamp cooler can run on battery power so you don’t need a generator. If you have a water hook up a misting system works wonders but you would not want to put it inside the tent. Take a trip anywhere above 7000 ft and you will be cooler….
Dc
dchuntnevada
Nevada
type portable misting system into any search engine and some cool stuff comes up.
