RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Hobo Dinner
Search only in Camp Cooks and Connoisseurs
Giggles
VA
Posted: 07/02/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
grandmashouse wrote:
fantasticfauna....
Normally I use the Reynolds large oven bags since they are very sturdy and already sealed except for one end. you add the goodies and then seal it up. But I haven't been able to find them in the stores lately, so I have been using heavy duty aluminum foil. I use 2 sheets on the bottom and 2 sheets on the top for strength, so they won't break open when you turn them. If you use the aluminum foil just be sure you seal them tight on all four sides.
hope this helps...
enjoy...
Paula
Do you lay the oven bags right on the grill? Or do you wrap the oven bags in foil also? If you lay them on the grill they don't melt?
Thanks.....
Mom4Nana2
Missouri
Posted: 07/02/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
We make this with a few leafs of cabbage on the bottom. Keeps it from burning if you make it in the coals + some of us like the cooked cabbage. We add a hamb. pattie, slice of onion,sliced potatoes, then our veggies and top with about 1/2 can of tomato soup. We always have to have these when we camp and once or twice in the oven through the winter. Sharon
DocNRed
Ut
Posted: 07/02/08 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
My wife taught me to wrap the food in one layer of foil, a double layer of newspaper, and another layer of foil. It takes a bit longer to cook and the newspaper burns but we have never burned the food, unlike my earlier days with only aluminum foil.
DocNRed
Some heroes wear capes, My heroes wear combat boots!
kihutson
Daleville, Indiana
Posted: 07/02/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
fantasticfauna....
hope this helps...
enjoy...
Paula
Thanks.....
Fulltime - - I think she's refering to the foil oven bags. You might be thinking of the plastic (turkey/chicken roasting) oven bags? Don't use those - - that would be bad!! Is that what you were refering to, fantasticfauna?
>> Kathy <<
Budster
Simi Valley, CA
Posted: 07/02/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
and you can cook these types on meals while you drive!
read about manifold cooking
Giggles
VA
Posted: 07/02/08 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Kihutson wrote...."Fulltime - - I think she's refering to the foil oven bags. You might be thinking of the plastic (turkey/chicken roasting) oven bags? Don't use those - - that would be bad!!"
Thank you so much, that is exactly what I was thinking! Of course, the foil oven bags...haven't seen them for a while.
Thanks again.....
FantasticFauna
LaSalle, Ontario, Canada, eh!
Posted: 07/02/08 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
fantasticfauna....
hope this helps...
enjoy...
Paula
Ok, that makes more sense, I understood one sheet on bottom 2 on top at first....
grandmashouse
Central Indiana
Posted: 07/02/08 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
sorry about the confusion, folks....you are right...don't use the plastic oven bags...that would be really bad...LOL if you use the oven bags (made of foil) they are heavy enough that you don't need to wrap them in more foil. If you use sheets of aluminum foil, use 2 sheets on top and 2 sheets on bottom for strength. yes, you put them directly on you gas grill on medium heat. If you put them over the campfire, put a grate over your fire ring and lay them on that. if you do this on a campfire make sure you have hot coals only, no flames. If this is cooked over campfire, the foil will blacken---this is normal for campfire cooking...that's also the reason why I add a little liquid.. so food doesn't dry out.....yes you can make individual pouches or 1 or 2 larger pouches..i try to make sure that they are all about the same size, so they all get done about the same time....
hope this helps with some of the confusion...
Happy Fourth!!!!!!!!
Paula
Hubby Steve
2004 Dodge Ram 2500HD QUAD CAB 4X4 5.7L V-8 HEMI
2004 Rockwood 27FKS-Super Slide
Paula
G&LWebb
Western NC
Posted: 07/03/08 03:49am Link  |  Quote  |  Print  |  Notify Moderator
fantasticfauna....
hope this helps...
enjoy...
Paula
Reynolds stopped making the foil oven bags a couple of years ago. Apparently they my werent selling well. I loved those bags as they made all the foil bag meals easy. I even used them to cover my beer can chickens while cooking on the campfire
George II and Lynne Webb
accompanied by George III and Dufus the wondercat
2007 FR Flagstaff Classic Super lite 831 FKSS
1500 Chevy Silverado 4X4
tvme
Medina, Ohio
Posted: 07/03/08 03:56am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip. That occasional "crust" that gets burned and stuck to the foil is my only problem with foil cooking.
Bob
