RichieO
Broward County, Florida
Our TT has an outside port to hook up cable TV but that jack does not work when hooking up a portable dish. My question is how to install another cable TV port on the outside of the TT so I could attach the cable from the dish to the exterior of the TT and then run cable with the TT to the area of the TV. Where on the TT would be best..underneath and then run cable???
2005 JayFlight 27BH
2003 Dodge Ram 1500 QC 4x2 Hemi 3.92 Super Springs
Our Photo's
jauguston
Bellingham, WA
There is a duplexer tee that you can put in the outside cable coax before the Winegard power booster that will let you use the same outside coax for either one. Sadly I did a favorites house cleaning yesterday and deleated the link I had for it. Someone will hopefully jump in here and post a link for it. You run a short jumper from one side of the duplexer back to the Antenna amp and the other side will pass power back to the antenna and you hook that side to the sat receiver. Quite clever.
Update -- solidsignal.com Eagle Aspen D2200 Duplexer
Jim
edited 07/01/08 05:21pm by jauguston *
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Eycom
Fl to NY
Here's a link to the mod using the existing cable in the RV to connect the dish to the receiver.
F-350 PSD/CC/DRW
Lance 1121-Nicely Appointed
jauguston
Bellingham, WA
I just looked at the link and I think the duplexer would be a lot easier.
Jim
Hgarnerno1
Tyler, Texas USA
I didn't really understand the link, so I went to radio shack and purchased 2 of the nipples that your cable screws into. I drilled a hole on the outside of the trailer and installed one of the nipples, then I did the same thing on the inside of the trailer near where the TV sits. I connected the two nipples with a short section of coax cable (also from radio shack). It works fine and is a neat looking installation.
Howard, USN Ret
2000 Ford Excursion,V10, Limited
2003 Terry 27H. Super Slide
RichieO
Hgar...
I was thinking of doing what you did...Im a bit nervosu of drilling a hole into the side of the TT. Did you purchase some type of cover or cap for the nipple thats on the oustide?
jeepinjimmy
washington
I did this mod yesterday and took me about an hour it was really simple the only hard part was making the opening bigger in the wall but not that difficult
RichieO
Jeep.
Can you post a pic of the mod please !
LarryJM
NoVa
RichieO wrote: Hgar...
I installed the nipples, one for cable and one for satellite in the refer access panel with some slack so the panel would hang should I need to remove it. Most refers have access to the interior of the trailer for the gas and electric lines. Of course if your refer is no where near your TV or on the opposite of the trailer this might not be the way to go.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
robbie69
wauconda, il usa
you can buy the kits at most rv stores(outside box, connecror, short length of cable)
i added 2 but usually use one. i put one outside where the cabinet for the dvd player is, use a splitter after the sat box and ran another coax to the bedroom tv. this is so the 2nd tv slaves off the livingroom tv.(also got the remote extenders from radio shack so the remote works in the bedroom)
i added the 2nd connector for the 2nd tv by a storage unit. when i bring 2nd sat box i just have to unplug the slave cable then hook up from the connector. i tried using an a/b switch but didn't want to work that way-probably need different type but i had this one laying around(and still is )most of the time i use the 1 box but like now, when we are gone for a while, i bring the 2nd box.
this way i left the cable in and bat wing in normal condition in case i ever needed them(radio runs through bat wing-dumb idea-basically helps the FM only-like to change that but so far haven't found a correct replacement for it) plus i'm not sure if you could run 2 boxes of the built in setup
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
