RV.Net Open Roads Forum: Travel Trailers: Coffee Maker
snarfattack
Chicago, IL
Posted: 07/02/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Do NOT simply replace the 20 amp fuse with a 50 amp fuse! 20 Amps is most likely the max amperage based on the length of the wire. This site has a car audio section down the page that will give you a safe wire gauge based on length and amperage.
http://www.epanorama.net/documents/wiring/wire_resistance.html
1999 Jayco Eagle 304BH
2003 Chevy Suburban 1500
keljohnso
North Carolina
Posted: 07/02/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
No, no, no, I wouldn't do that. Actually, I'm looking to replace the wire with some #4 and about 150 amp fuse or circuit breaker. I found the manual for the inverter and got some info. Thanks!
2oldman
WA
Posted: 07/02/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
lol
Rick From Sequim
Sequim, WA
Posted: 07/02/08 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Like AlanB says, or to repeat Watts = amp times volts. Therefore, 600 watts at 120 volts, draws 5 amps. An inverter drawing 12 volts to deliver 600 watts = 600 / 12 = 50 amps.
Ain't no free lunch. A watt is a watt is a watt, regardless of the voltage.
Rick
& wife Loie & Kodi Dog (blk male std poodle)
1995 F-250 460 Banks (wow!) & 2005 25' Bigfoot RQ
The_Vintagers
Georgia USA
Posted: 07/04/08 03:08am Link  |  Quote  |  Print  |  Notify Moderator
anything that heats or cools pulls more power. I suggest a coffee maker to put on the stovetop.
javaseuf
California's Gold Coast
Posted: 07/04/08 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Except a swamp-cooler.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
keljohnso
North Carolina
Posted: 07/04/08 07:10am Link  |  Quote  |  Print  |  Notify Moderator
We tried that, it takes too long. I'd rather use battery that can be recharged, than 45min. worth of LP.
javaseuf
Posted: 07/04/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
45 minutes worth of propane? It takes my 2 quart tea kettle about 12 minutes to reach boiling and I have enough hot water for 10 cups of coffee. And I do believe the propane will be cheaper that gas for a gennerator to run the coffee maker or charge your batteries after the invertor draws them down.
Ans since a genny will be needed to recharge the batteries, unless you have solar, why not just run the genny to power your coffee maker?
