Chickie
Slatington,Pa USA
My wife has acid reflux and at home we have raised the head of our bed. Has anyone done this in their toy haulers? We have a queen bed with storage underneath it. I am thinking about building a wedge to put on the bed frame and in under the mattress. Suggestions?
Good Sam Life member
GWRRA member
NRA Life member
2002 F350 Lariat SC 4x4 PSD 6 speed,
2008 Goldwing GL 1800/2008 CSC trike conversion
2008 KZ Sportsmen Sportster 35'
Retired and loving it.
damone
Paradise,CA
I say take the whole cover/top matress support off and build the wedge on the frame then lay the top back down as before. There will be no need to build an entire frame with support for the matress if using the existing top.
"Honey, are the brakes suppose to touch the floor"
RideRed,
D
BigJon05
Ripon
They sell foam wedges at mattress stores or look online.
05 Eclipse Attitude 26'FSAK
03 F350 PSD longbed, 6" lift BFG 35
08 Polaris RZR
07 Can-am Outlander 650 MAX XT
2 Can-am DS650 00/01
1 TTR 90
1 Redcat 110
1 Unison 50
1 Honda XR50
maddog348
Bakersfield,CA
Go on-line 'inflatable bed wedge' got lots of choices. I Have built in/up wedge (Captians bed - drawers under) at home (GERD) have been looking for one for the MH. Now just have to decide which one.
old guy
Oregon (pronounced Or e gun)
have you tried Gaviscon before you go to bed at night? My Dr. had me start on it and it has done a lot for me. I no longer need to sleep on the wedge. the Gaviscon coats the opening to the stomach and cuts back on the burning
Chickie
Slatington,Pa USA
Old Guy, the DW was on medication but we found by just raising our bed by the thickness of on brick she doen't need any medication anymore. so we figure no med is better than some meds if it can be helped. I have been on line and there sure are a lot of different varieties. I really was thinking of just raising the head by 3 inches. That should be doable without to much trouble. I actually sleep better with my head raised also.
JSGrewal
Simi Valley, CA
I saw someone ( on here I think) that built a simple riser that added height and storage to his flip up bed. I think they even angled it too. It would be really easy to just use the same type construction the bed is on now, but higher and angled, fitted inside the original. Move the hinge and supports to the new piece and you are all set. If you are clever how its attached, you could remove it if you sell the trailer and leave no trace behind...
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6
