RV.Net Open Roads Forum: Travel Trailers: Water Pump Failure
 > Water Pump Failure
Evedave
Canada
Posted: 07/02/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Hi there,
Have a question about our water pump that seems to have stopped working. Our trailer is new, have had it out a total of 10 nights. We camped in it this weekend at an un-serviced spot and had filled up with water on the way out.
Everything was fine all weekend. Yesterday we brought it to the dumping station, dumped, and loaded up with more fresh water for this coming weekend.
Got it to the site and turned on the pump. Pump was priming, priming, priming, no water.....for a very long time. Truned off the pump and started the generator, thinking maybe we needed more power.
Tried the pump again and nothing-even the light on the switch that indicates the pump is working didn't come on.
I'm stumped! I would hate to have to bring it in for repair in the heart of camping season.
Am I missing something obvious here (am a newbie) or am I up the creek?
2007 Toyota Tundra V-8 Off Road Package
2008 Tango 256RKS
Riley (small brown terrorist)
Cooper (large blonde terrorist)
amaze
Ohio, New Albany
Posted: 07/02/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried it since? The pump needs the water to keep it cool. It might have overheated. Or it might have blown a fuse. The worst case scenario is it burned out the pump motor. If it was the last case scenario and you don't want to part from your camper for a week or two, you could replace the pump for $80 and an hour of your time. You could also try and work out a deal with the dealer you bought it from and they would exchange your old pump for a new one.
2Rad4U
I'm to young to be a
Posted: 07/02/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
If the light on the switch is not working, it's not a pump problem, it's a power problem. Check the fuses and/or breakers and wiring.
CB
PSU1999
New Wilmington, PA
Posted: 07/02/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
"Posted By: amaze on 07/02/08 03:20pm
Have you tried it since? The pump needs the water to keep it cool. It might have overheated. Or it might have blown a fuse. The worst case scenario is it burned out the pump motor. If it was the last case scenario and you don't want to part from your camper for a week or two, you could replace the pump for $80 and an hour of your time. You could also try and work out a deal with the dealer you bought it from and they would exchange your old pump for a new one."
I don't think the above is true. These pumps are made to run dry, you can hurt the water heater with no water but not the pump.
Me - PSU 1999
Wife - Also PSU 1999
Daughter - Hopefully PSU 2026
Daughter - Hopefully PSU 2029
2003 Starcraft Aruba 27sks TT
2004 Chevy Trailblazer TV
dbbls
Missouri
Posted: 07/02/08 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
When you turn the pump on (after you get it working) open one or two faucets and it should prime. After it starts pumping water close the faucets.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
javaseuf
California's Gold Coast
Posted: 07/02/08 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
You are correct. It doesn't need water to keep it cool since the pump head that contains the diaphram is pretty much isolated from the motor by the plastic housing.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Rosehill
Central West Texas
Posted: 07/02/08 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
If the pump is now totally dead and the indicator light isn't working, then you have a power problem. Check fuses and connections.
As for the original problem, I had this about a year ago. Never could get it to pump, pulled the pump, checked it out, it was fine. Pulled the freshwater tank and SOMEHOW a small piece of plastic bag (think wal*mart bag) had gotten in the tank and into the tank strainer that the pump pulls water from. Removed bag, pump worked fine. Since your TT is new, perhaps something is in the tank?
Me and DS
Velcro and Minnie the felines, a bunch of Borzoi
1992 Dodge B350 "The Dawg Van"
1987 Kit Road Ranger Model 199 "The Dawg Haus"
"It's not old, it's vintage!"
khall34
CT
Posted: 07/05/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
We ran our pump dry while flushing our tanks. Then it would not prime. We did all the normal things to get it to prime, but no luck. Turns out it was a vapor lock in the fitting that connects the pump to the intake/ outlet hoses. Try unscrewing the plastic nuts and breaking the vapor lock. Worked for us.
MaddogBC
Kelowna BC
Posted: 07/05/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Great advice there
Not knowing this cost me 108$ and a trip back to civilization last week.
But on the plus side I now have a good backup in case the new pump ever fails
Rob
