RV.Net Open Roads Forum: Around the Campfire: Gas At Safeway
 > Gas At Safeway
dgo1369
Georgetown, TX, US
Posted: 07/02/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
I went food shopping at the Safeway in Montrose, CO yesterday and after paying, I was told that because I spent over $100, I automatically got .10 per gallon off the normal price. Not only that, but it is cumulative. In other words, if I spend at least $100 on four occasions, I will get .40 per gallon off. I don't know how long this will last or if it is system wide, but I sure like it. You may have to have a Safeway card (which is free), but I'm not sure about that.
Dennis Osha
coolbreeze01
Redding, Ca
Posted: 07/02/08 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Here it was .20 gal off with a $50 purchase.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
mowermech
Billings, MT
Posted: 07/02/08 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Albertson's has a similar arrangement with Holiday Stations/convenience stores.
The coupons also work at the Albertson's Express gas stations. The Albertson's express card also gives $.03 per gallon off at the pump at the Albertson's stations.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
dgo1369
Georgetown, TX, US
Posted: 07/02/08 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, but in CA everything is so expensive that regardless of how much is discounted you are still getting robbed!
* This post was edited 07/02/08 07:40pm by an administrator/moderator *
coolbreeze01
Redding, Ca
Posted: 07/02/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
lol
Kajtek1
CA
Posted: 07/02/08 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
"cumulative" means that after spending $100 four times at Safeway grocery, you will get 10 cent discount on four fuel purchase. I had a glitch that didn't give me the discount on the first card sweep, but did on the second. The station attendant told me that I need to contact headquarters to straight it up. For one dollar and twelve cents ????
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
dgo1369
Georgetown, TX, US
Posted: 07/03/08 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Here it means that if I "save" up four times, it will be .40 per gallon cheaper when I fill up. I'm not sure what you are referring to with the $1.12???
Kajtek1
CA
Posted: 07/03/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
The $1.12 was the difference between normal 3% discount and the 10% discount that computer glitch didn't give me. I am not starting headquarters case for this amount.
Are you sure your Safeway will multiply the discount on single fuel purchase? It never happened to me.
goin2themountains
Aztec, NM
Posted: 07/03/08 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Naw. You will just get the discount on a larger number of fillups, not on a single purchase. Also, the Safeway in Farmington,NM just told us they were dropping the incentive. Bummer, I really looked forward getting that 10 cents off.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
donn0128
Pronounced Ore-gun
Posted: 07/03/08 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Of course their food prices are always 15% higher, so they need to keep you coming back some how!
Donn
 > Gas At Safeway
