RV.Net Open Roads Forum: Towing: Too low for wt distr hitch?
Search only in Towing
Open Roads Forum  >  Towing
 > Too low for wt distr hitch?
jim83m
Upstate NY
Posted: 07/02/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I tow a small trailer with a GMC Savana 1500. I'd like to use a wt distribution hitch but my trailer is really low to the ground, only about a foot ride height.
This means there isn't much room under the hitch for the bars to attach. Is there a way to raise the entire deal up or otherwise configure a solution?
Thanks,
Jim
skipnchar
Topeka Kansas USA
Posted: 07/02/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
With that small a trailer I have to ask, "why would you need WD on it/" Excuse my ignorance but I thought a savana was a half ton truck.
BarneyS
S.E. Lower Michigan
Posted: 07/02/08 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
The Equal-i-zer hitch should work. Also the new Reese Pro Series hitch should work.
Both of these hitches combine WD with sway control and do not stick down below the A frame as far as a normal WD hitch does.
Also, are you sure you need a WD hitch with a small trailer? What is the tongue weight and what kind of trailer are you pulling? That info would help others give you more informed responses.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
dodge guy
Chicago, western subs.
Posted: 07/02/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
What type and size of trailer?
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
jim83m
Upstate NY
Posted: 07/03/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Actually, I don't know if it's called a half ton or quarter ton van. The GMC website is mum on that description.
The trailer is 3500 pounds (small compared with what many of the people on this forum pull) with a 350 lb tongue weight. With the trailer hitched up and nothing stowed in the back of the van, there is a slight sag. I'd like to get more weight back on the front tires without reducing the tongue weight.
This is why I am considering the wt dist hitch.
Jim
mkirsch
Rochester, NY
Posted: 07/03/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Pish and pshaw.
You're pulling 70lbs off the front wheels, tops. That's not enough to cause a handling/safety issue. The weight on the front wheels varies by that much with the front-seat passenger.
For giggles, measure the height of the fender wells unhooked, then hooked. You'll see it barely makes the front end lift.
Tmeek
Jackson, MS
Posted: 07/03/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Skip - I can assure you a Savana is a van! 1500 is the half ton (mine's a 7100# gvw model) Sierra is the pickup.
Jim - how high off the ground is the hitch ball? When you're hitched up, does the trailer appear to be level, nose up or nose down?
I'm curious because even when I use my standard weight bearing hitch ball in my hidden hitch receiver below the rear bumper, I have plenty of room for weight dist. bars...
2000 GMC Savana, 2007 HR Aluma-Lite 8308S
jim83m
Upstate NY
Posted: 07/03/08 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Tmeek,
All hitched up, the nose is up. Not a lot. But its up. If it doesn't matter, then great. I've been towing this trailer for 10 years with another vehicle and the van is new to me. Maybe I am over reacting.
But the trailer is low. The female end of the hitch is only about a foot off the ground. I had to readjust the male end of the hitch downward because of course the van is higher than the Roadmaster I had been towing with before.
Thanks,
Jim
LarryJM
NoVa
Posted: 07/04/08 02:21am Link  |  Quote  |  Print  |  Notify Moderator
Jim
I don't think I would put a WD setup on that trailer for fear of damaging the trailer A-frame section. It's not made to handle some of the extreme loads that a WDH can put on the trailer frame. You also need to get that trailer level when hooked up and definitely not nose high.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/04/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
You can beef up the rear suspension on the van to take care of the rear end sagging, therefore eliminating the need for weight distribution. You will then need to re-level the trailer with a lower drop ball mount or adjust your adjustable ball mount lower if it can go lower.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
