Tmeek
Jackson, MS
Jim, if that's the case, you may want to consider raising the trailer in some way - but only if you are having a sway problem...
2000 GMC Savana, 2007 HR Aluma-Lite 8308S
hilldude
Red house WV
A WD hitch will give a better ride.I had a TT with the same weight, used a 400 lb hitch with one weight bar worked well. but it will not fit some trailers because of the way it is made.
