RV.Net Open Roads Forum: Fifth-Wheels: Adjusting Mor-Ryde Suspension on 08 Jayco
 > Adjusting Mor-Ryde Suspension on 08 Jayco
tmb4971
upstate SC
Posted: 07/03/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Anyone tried to adjust the Mor-ryde suspension themselves. I would like to raise mine up to the next set of holes and hate to take it back to the dealer if I can do it myself. This is on a 2008 Jayco Designer. I've read where others have had it done but haven't seen where anyone has actually done it themselves.
If you've done it can you share how you did it.
Thanks!!
Tommy & Sherry
2002 F350 Lariat 4x4 Ext Cab 7.3 Diesel w/Edge Attitude/4" exhaust
2008 Jayco Designer 31RLTS
BraamRW
Raleigh, NC
Posted: 07/03/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I am assuming you are talking about the pin box not the axle suspension. I have lowered mine one hole which in turn raised the 5th about 1 1/4" additional clearance over the truck sides. I used a floor jack (can use a bottle jack) on a stand under the pin box and removed the bolts. However, the pin box was tight on the 5th bracket and I had to force the pin box to drop. It was a very easy process.
2006 F-350 King Ranch crew cab short bed
Backup camera for bumper hitch and camera for 5th wheel hitch
Kenwood audio/video system with a 6 1/2'' screen
Pullrite 16K superglide hitch
35TMS Grand Junction 5th wheel.
tmb4971
upstate SC
Posted: 07/03/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I'm talking about the suspension itself. I have the pin box too but it's ok. Thanks
Charlie Q
Brusly, Louisiana
Posted: 07/03/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
I am going to raise mine in the next couple of weeks. It's not going to be that difficult as I just had it all apart a few weeks ago installing the wet bolt kit and changing the plates in between the springs. Since then, I have installed a 5th airborne pin box and want to level the rig out again.
To answer your original question, when I installed the wet bolt kit, I lowered the front landing gear really low, jacked up on the frame on each side behind the axles with a 20 ton bottle jack. Braced the frame up with boards and put heavy jack stands under each side of the frame. Lowered the rear stabilizer jacks just for added security and raised the front back up some. I then removed all 4 tires and replaced 1 side at a time. It took me a few hours to change out the bolts. The worst part was hitting my finger once.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
Dayle1
Spicewood, Tx
Posted: 07/03/08 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Is it the IS suspension or the RS? With the IS, it should be just a little more work than changing a tire. Once the tire is removed, put a jack or other support under the end of the swing arm before removing the bolts that secure the rubber suspension. On mine, there is just one additional set of holes available that would raise the trailer 1 inch.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'03 GMC 2500HD D/A EC SB, Jordan controller, custom RKI bed/hitch, Putco boards, TF 45gal tank, grey Speedliner
'04 CrossRoads Cruiser CF29RK, Mor/ryde IS, Carefree Eclipse 12V awning
Rig Photos
tmb4971
upstate SC
Posted: 07/03/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if it's IS or RS..Not sure what's the difference. I'll look in the paperwork that came with the unit. Theres only 1 hole that I can raise it up. Looks like there are some smaller bolts in the center where the mor-ryde assembly is that also needs to be moved.
tmb4971
upstate SC
Posted: 07/03/08 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
After looking at Mor/Rydes website it looks like I may have the RE system..
jimwooster
Wooster, Ohio
Posted: 07/03/08 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Which Designer model do you have We have an 07 34RLQS and love it. I am not sue I would adjust the Mor Ryde, but maybe just the hitch height. I let the dealer handle it anyway. Too many major things can happen and that is delicate territory!
Hope you like the Designer.
Jim
tmb4971
upstate SC
Posted: 07/03/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Jim,
We have the 31RLTS and love it too. I'm a little nose high and lowering the hitch or raising the oin box will get too close to the bed for my taste. I would like to get additional room for the rear landing gear as well. Looks like I might gain 1-1/2" if raising the mor/ryde susp. I may get the dealer to do it if it's too big of a hassle to do myself.
Thanks
Charlie Q
Brusly, Louisiana
Posted: 07/03/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
PM me your email and I can send you the 2 prints that mor ride sent me. They may help you determine which suspension you have. I can't figure out how to attach a file.
