RV.Net Open Roads Forum: Fifth-Wheels: Adjusting Mor-Ryde Suspension on 08 Jayco
 > Adjusting Mor-Ryde Suspension on 08 Jayco
2007dura
Hendersonville, NC
Posted: 07/03/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I had the dealer raise mine. Mine was nose high too, really helped. Now have good clearance for bed rails too.
2007 Classic 3500HD DRW/LT3 Duramax/Allison
2008 Jayco Designer 35RLTS
whiteeye42
i have a 2008 jayco eagle 341RLQS and my trailer has the jake plates on the springs mine has 2 more holes on the springs and one in the center on the rocker i tried to raise mine using bottle jacks and placing a floor jack under the axle but i could not get the bolts to come out of the springs so i guess i will be taking it back to the dealer so he can do it not sure if i was doing something wrong but i need to raise my trailer to clear the bed rails of my new dodge truck
Me,Wife two boys ages 20 and 17 also two dogs
2008 Dodge Ram Quad Cab 4x4 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with b&w turnover ball & companion hitch
using rotochoks
add state map
Charlie Q
Brusly, Louisiana
Posted: 07/03/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
whiteeye42,
The bolts have to be driven out using a punch so that you don't mess up the threads. Not that hard. They have splines on the head/shoulder end to prevent them from rotating because the nuts are not tightened all the way so that the springs can move up and down without wearing out the hanger plates. When re-installing the bolts, you will need to drive the splines into the new holes.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
tmb4971
upstate SC
Posted: 07/03/08 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Charlie Q,
Thanks for the drawings. I do have the RE system.
Tommy & Sherry
2002 F350 Lariat 4x4 Ext Cab 7.3 Diesel w/Edge Attitude/4" exhaust
2008 Jayco Designer 31RLTS
Ninebell
Bardstown,Ky
Posted: 07/04/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Call Mor-ryde they are very helpful and don't mind spending alittle time on the phone.You can also e-mail them they've always answered my questions.Good luck and hope you enjoy your designer we do.
Ninebell,the Wife,and Ginger the Shiz-zhu
2008 F-450 Lariat PSD,DRW,CC,LB,4X4
2007 Jayco Designer 34RLQS.
My Photo's
cruz
Prescott, AZ
Posted: 07/04/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have an '08 Designer 35RLTS and had the dealer raise it for me. Gained right about 1 3/4" ... just what I needed !!
It's a 2 hour job at the dealer ... pure labor.
The key is lifting the entire trailer off the ground so the tires are at least 2" off the ground. If you can do this, then it's a matter of 10 bolts per side ... take the wheels off ... support the axles, take out the bolts ... carefully lower axles into place, and replace the bolts ... make sure your brake wires are loose enough first!
Keep in mind your shocks will not be long enough once it's lifted. MorRyde told me the shocks are not really needed with this suspension, so I left mine off. Can't tell the difference !!
Would I try it myself ... probably, But for $200 I chose to let the dealer do it so there's no question if something should happen down the road.
HR & Beth
2006 Chevy Silverado LT3 3500HD, DRW, D/A, CC, LB, 4x4 and RED
Cassie - pure Black Giant Schnauzer
Mollie - pure White Mini Schnauzer (the boss)
tmb4971
upstate SC
Posted: 07/05/08 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advice guys. I've looked it over and it doesn't look to be very hard to do. I may give it a shot. I think I can get access to the truck garage where I work and use the truck lift to lift my camper. If not I'll have my dealer do it. They talked me out of having it done last time I was there.
Thanks
2007dura
Hendersonville, NC
Posted: 07/05/08 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Why did your dealer say not to do it?
tmb4971
upstate SC
Posted: 07/05/08 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Probably because it was Saturday and my appt was at 12 noon. They close at 3 and I was there for other warranty items to be fixed as well. I told them when I made my appointment that I wanted it done. I don't think the service dept realized it was the Mor/Ryde susp until he looked underneath. I let him talk me out of it. He said it was a major undertaking to raise and I didn't know any better at the time. I do now!!
Thanks
NHIrish
White Mountains NH
Posted: 07/05/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Mor-Ryde in my Cameo, and just dropped it off at the dealer for some warranty work. While there, I asked....and was told it was about a 20 minute job...only the wet bolts need to move...nothing on the axle itself....just moving the leaf spring connection points. So, I added it to the list. Might as well adjust the brakes when the wheels are off the ground too!
2008 Carriage Cameo 31KS3
2006 Ford F-350 PSD long bed
B&W Companion
Diplomacy is the art of saying 'Nice doggie' until you can find a rock
