kehale
Texas 2007
06 Lance 1181
Has two group 27's in there now on a tray, but I've let them die (11.x volts) too many times.
What's a good replacement size/brand?
Any advice is appreciated.
06 Lance 1181 on heavy duty Ford pickup
silversand
Montreal
Kehale: what specifically do you have? Gel cell? AGM? Flooded cell?
I'd suggest AGM batteries if you don't already have them. If you had them and destroy AGMs, all I can say is: wow! You're a better man than I! I couldn't kill our AGM batteries no matter what I did
Cheers-
Silver
Steve_in_29
29 Palms (SEMPER FI), CA 92277
How do you use your camper? Campgrounds or long boondocking trips? If campgrounds then simply replace them with the same batteries and continue on. If boondocking then a switch to something like Trojan T105's or even Lifeline AGM batteries might be in order.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
Mooney
Santa Barbara, Ca
My 1181 has the group 31 Lifelines . . . love them!
'08 Ford F550, Lariat, Link Air Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'05 Lance to-the-Max (Sold)1181.
'09 Host Everest
YC 1
Yuba City Calif.
Measure the hole and fill it up. !
Gary3
Windsor, ON
I just traded my two 27 for 29,s they fit with room to spare if I wasn,t so cheap I would have bought the lifelines also. The 29,s give quite a bit more than the 27 did even though we never sat for more than 2 days and have a 125 watt solarpanel.
Gary Lance 1181 solar Gen.
Paoli
Quesnel BC
Would it help to keep the camper hooked up to electricity?
Some people told me it's a good idea, others said it's not.
Last year when my camper was off the truck I kept it plugged in all winter.
My battery is at least 6 years old and still works.
What's right, what's wrong....heck if I know, maybe someone here knows?
oklamtnbkr
SouthWestern ,Oklahoma
Are you using the kill switch when storing the TC? Or just running down your battries? If your going to fork out the bucks for good AGM battries,look at upgrading your charger unit with a "smart charger".As for battries I've got 2 Optima's and am happy with them but will go for BIGGER AGM lifelines when these die.
2006 GMC 4X4 CC DM/A 6spd DRW Timbren's on all 4 corners, Rancho's Torklift's,Fastguns 2004 BigFoot 30.11SL
kehale
Texas 2007
Mooney wrote: My 1181 has the group 31 Lifelines . . . love them!
I'm just running the stock batteries now (interstate?).
Where did you get those lifelines?
Since we have the same camper, I'm pretty sure they'd fit.
kehale
Texas 2007
oklamtnbkr wrote: Are you using the kill switch when storing the TC? Or just running down your battries? If your going to fork out the bucks for good AGM battries,look at upgrading your charger unit with a "smart charger".As for battries I've got 2 Optima's and am happy with them but will go for BIGGER AGM lifelines when these die.
I've got the upgraded progressive dynamics charger.
My fault for killing them. Once left some lights on inside and nearly drained them completely. Another time I left the radio on. Doh!
Those AGM's look pricy!
