RV.Net Open Roads Forum: Folding Trailers: cross country
 > cross country
druk62
bloomington illinois
Posted: 07/03/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
im going to pull my 2004 fleetwood yuma from illinois to california this summer, is it ok to pull one that far?
Mike & Bernette
2007 mitsubishi raider
2006 kodiak 17 fl
tom_kat
way upstate new york/lake george area
Posted: 07/03/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
just make sure your up to date on your maintance and check your brakes,tires and pressure ,wheel bearing and seals,springs and spring hangers check the u bolts for being tight,ect.do the maintance for your tow vehical also.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
10tca01
Columbia Missouri
Posted: 07/03/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Of course! We just got back from towing our Palomino Yearling from here in Columbia Mo. to Niagara Falls N.Y. through Canada. Like tom kat said though, make sure you're up to date on your maintenance.
Tyler
Biznaga
Arizona
Posted: 07/03/08 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
Pulled mine from Washington to Arizona and back in March of 2006 and back to Arizona in May of 2006 when I moved back. Nary a problem.
And from AZ to WA round trip last May, June and July.
TV: 2004 Explorer Sport Trac
Home away from home: 2003 Jayco Eagle 10UD
Never try to teach a pig to sing. It wastes your time and annoys the hell out of the pig.
pete42
Jamestown, Ohio
Posted: 07/04/08 07:00am Link  |  Quote  |  Print  |  Notify Moderator
2 Years ago I traveled from Ohio to California and back.
last year I spent 2 weeks in Florida in the spring.
and 3 weeks in the summer Ohio to Maine.
Keep the axles lubed and the tires pumped up and enjoy your trip.
I went to southern California what part are you visiting?
PETE
Huntin4Pixels
Las Vegas, NV
Posted: 07/04/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
No sweat! Speaking of sweat, what route are you taking. I highly recommend a northern route if your planning your trip during the hotter part of the desert southwest's year (June thru September).
Don
Sometimes I do get to places just when God's ready to have somebody click the shutter - Ansel Adams
druk62
Posted: 07/04/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone, I'm heading to southern California, family matters, in late July, so I must use rout 40 (66) through the dessert, I will travel at night most of the trip, witch is a round trip at that.
Stumps
valley of Virginia
Posted: 07/04/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Have fun, I love camping along the way each night.
I would highly recommend taking two things with you:
make sure your lug nut wrench and jack work on your camper before you leave home. You might even want to test-change a tire in your driveway.
take a portable air inflator for your tires, and before you leave each day, CHECK YOUR AIR PRESSURE and top off as needed.
have fun!
04 Isuzu Ascender
04 Jayco 12FSO
Pete Rose - 4256 steroid free hits and still not in the Hall of Fame!
PattieAM
Maryland
Posted: 07/04/08 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Before leaving on your trip, please be sure to have your tow vehicle's oil changed, and check those fluids daily - carry a spare bottle of antifreeze/water in the event you overheat, and check/replace the belts as needed.
It can be a beautiful trip - enjoy what you can en-route.
 > cross country
