RV.Net Open Roads Forum: Towing: Some People Are Clueless
Search only in Towing
Open Roads Forum  >  Towing
 > Some People Are Clueless
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 07/04/08 01:17pm Link  |  Print  |  Notify Moderator
It could be worse...the salesman could have told the owner the "sure, it'll tow anything, even a 5th wheel!
mowermech
Billings, MT
Posted: 07/04/08 01:30pm Link  |  Print  |  Notify Moderator
I disagree with the "WD help" idea. What the guy needs is a bigger tow vehicle. That Honda is inadequate for a 22 foot trailer, WD or no, sway control or no.
I am constantly amused by the "band-aid" approach to RVing. If there is a problem, don't FIX it, put a band-aid on it. WD hitches with sway control are more often than not "band-aids"!
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
skipnchar
Topeka Kansas USA
Posted: 07/04/08 03:01pm Link  |  Print  |  Notify Moderator
I've seen MUCH worse than that with 3/4 ton trucks and 5th wheels. A 22 foot trailer is more than likely not that heavy so should be within the limits of the truck but it's not very well set up.
LarryJM
NoVa
Posted: 07/04/08 03:47pm Link  |  Print  |  Notify Moderator
mooreadventures wrote:
I saw this going S on I85 outside of Charlotte yesterday. Unfortunately I didn't capture the entire set up, but I think you can clearly see that this Honda Ridgeline needs some WD help.
The trialer was ~22 ft toy hauler with a fold down ramp in the rear... I wonder what was inside.
That's really scary down in the rear light on the front and no sway or WD so the first time it bounces and starts to sway you have little steering control. I hope his break away works and has a good battery so he doesn't kill some innocent family.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
Garfie|d
South-Western Ontario
Posted: 07/04/08 03:54pm Link  |  Print  |  Notify Moderator
Well call me crazy, but it doesn't look all THAT bad to me compared to what I've seen on the highway.
2001 Airstream Safari 25SS tugged by 2001 GMC Yukon 5.3L 3.73
Hensley Arrow • Jordan Ultima • Barker 3000 • Mckesh
LarryJM
NoVa
Posted: 07/04/08 05:03pm Link  |  Print  |  Notify Moderator
O.K. your crazy If I see a rig like that I speed up and get in front and stay there cause I don't want to be behind it when it wrecks.
Larry
mowermech
Billings, MT
Posted: 07/04/08 06:12pm Link  |  Print  |  Notify Moderator
No, you aren't crazy. I don't think it looks all that bad, either. I have seen worse, and I have driven worse. Nobody died.
chadsalt
sc
Posted: 07/04/08 06:24pm Link  |  Print  |  Notify Moderator
Looks dont mean much. You dont really know any of the specifics of that Honda/trailer to begin with. Ive towed 600# tongue in WC on the Trailblazer I used to have, Chevy said 400# WC tongue was the limit. It "looked" a WHOLE lot worse than that Honda did. Not that Im necessarily recommending it, but I got where I was going every time.
Mont G&J
Missoula, MT
Posted: 07/04/08 06:35pm Link  |  Print  |  Notify Moderator
Ditto, Nice looking rig. He's probably within weight limits and with a good brake controller should be well in control.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/04/08 09:28pm Link  |  Print  |  Notify Moderator
Those 'trucks' have very soft rear suspension. It wouldn't surprise me if he is within his weight ratings but the truck just can't hold up the load cause the mfgr made it ride like a car not a truck. Being 'within the weight limits' doesn't necessarily mean you're 'good to go' with your rig though....
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
