RV.Net Open Roads Forum: Hybrid Travel Trailers: Sewer Line Connection
Open Roads Forum  >  Hybrid Travel Trailers
 > Sewer Line Connection
dtzackus
Cumbola, PA
Posted: 07/04/08 10:56am Link  |  Quote  |  Print  |  Notify Moderator
What does everyone do or maybe there is a trick to this, but at our last sewer hook up, the top of the drain was a little higher than our dump value, so I had to dump the tanks and then pick up the hose to have the "unmentionables" go down the drain. I went to the local Wal-mart and bought a sewer line hose holder whiched helped a little, but I still had to pick up the hose to make sure everything went down.
Is there a trick that maybe of have helped or am I stuck, "picking up the hose"...
Thanks...
Dan
Dan, Tammy, Cory, Leah and Adam
2003 Chevy Silverado Extended Cab Truck
2006 19 HTT Keystone Zeppelin
Equal-i-zer Hitch
Prodigy Brake Control by Tekonsha
Polishnurse
Schodack, NY
Posted: 07/04/08 11:01am Link  |  Quote  |  Print  |  Notify Moderator
The trick is simple, start with your left hand when you pick up, then right. Alternate between the two, left, right, left right.
bldrbuck
Boulder, Colorado
Posted: 07/04/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
While it is not convenient the answer is to run you unit up on blocks so the outlet is higher than the dump.
dtzackus
Cumbola, PA
Posted: 07/04/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I guess I am still a rookie, I did not even think of that. Next time I will have to check that out, I also noticed that the campsite sewer connections where a bit high, they must of been out of the ground a good 8 inches which I thought was very high. O well, at least my sewer hose is still new and did not have to worry about holes.
want-a-be
Indiana
Posted: 07/04/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Try the Sewer Solution. Do away with 3" sewer hose and will dump up hill.
Check it out at Tweetys.com
* This post was edited 07/04/08 01:28pm by want-a-be *
skipnchar
Topeka Kansas USA
Posted: 07/04/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
If you're talking about a "sewer line" just leave it alone and it'll go down from pressure ahead of it next time you dump. If you're talking about the "dump station" pick it up and move on. good luck / Skip
* This post was edited 07/04/08 02:45pm by skipnchar *
Bumpyroad
Virginia
Posted: 07/04/08 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
the trick is to throw away the stinky slinky and buy either a sewer solution or macerator pump. makes a dreadful job, almost fun.
bumpy
Polishnurse
Schodack, NY
Posted: 07/04/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes Sir, macerators are fun, they turn a 15 dollar job into a 200 dollar job, and they can be dual functioning, just put a nozzle on the end of the hose and you can fertilize the front lawn while emptying you black tank.
Bumpyroad
Virginia
Posted: 07/05/08 05:48am Link  |  Quote  |  Print  |  Notify Moderator
and the value of doing away with a stinky slinky, "priceless".
bumpy
Polishnurse
Schodack, NY
Posted: 07/05/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
LOL,,,, was waiting for your response, Hope your haveing a great weekend. Bill
