RV.Net Open Roads Forum: highway 20 in california from I5 to 101
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > highway 20 in california from I5 to 101
donn0128
Pronounced Ore-gun
Posted: 07/05/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
YC 1 wrote:
Take Highway 20 West out of Williams. 37.1 miles.
Watch for Highway 53 as you drop down a hill after a fairly long climb. Easy climb and multiple lanes.
Turn South onto 53. You will go about 8 miles. Look for the sign to Highway 29 which leads to Kelseyville. This is a nice road and will become freeway in a few miles. Eventually you are back to two lane for a short distance and will come to a stop sign. You are back to Highway 20 again. This leg is about 30 miles. Turn left and enjoy the beautiful drive right to 101
This route will bypass the two lane twisting and winding on the North side of Clear lake. If you want a good view of the lake go ahead and stay on 20 all the way to 101 instead of the bypass described above.
And I am indeed someone that took a 30 footer with a Toad up route 1. It is a scenic route with some tight turns but I use turnouts when possible. The Willits road from 101 to Ft Bragg is very twisty but in excellent condition with plenty of turn outs. Use low gears and take your time. It will take you most of an hour to traverse the 33 miles.
X2 Much easier drive.
Donn
ratherBcampin
The nice one from Nice, Ca 95464
Posted: 07/05/08 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
If you are coming to highway 20 from the south, take highway 16 out of Woodland to hwy 20.......You will cut about 30-45 minutes off your time and will miss some of the grades....
The more scenic rt (staying on 20 to 101) is not only the shortest, but also the quickest rt.
The town of Lucerne has a nice park across the street from a Fosters Freeze that makes for a nice road break.......The hot fudge/brownie parfait is to DIE for!
Proud supporter of
Operation Tango Mike
If you can't stand behind our troops.....Then stand in FRONT of them!
