RV.Net Open Roads Forum: Technology Corner: Refreshing Router
 > Refreshing Router
RetiredBob
Portage, MI
Posted: 07/05/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Can anyone explain why I need to refresh my wireless router every 2-3 days? I'll notice problems while surfing, check my connection and see that I'm actually connected via a neighbor's network. I go upstairs, disconnect power cord to router, wait 30 seconds and plug it in, and have Excellent or Very Good conectivity. It's not a major issue, but I'm curious and, if possible, would like to eliminate the problem.
Tvov
CT
Posted: 07/05/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
I also seem to have to do that with my wired router every few days or so. I have no idea why.
2008 F-250 CrewCab 5.4L,
Joy
Henderson KY 42420
Posted: 07/05/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
When my wireless router was installed, I was told to reboot it this way any time reception slowed. No explanation as to why, tho.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
pulsar
Lewisville, NC
Posted: 07/05/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
It may be of some help if you told us which router you have.
We have a LinkSys WRT54G (see below) that will disconnect about once every month or so. It has been doing that for a few years now. At first I tried to figure out the cause, but just live with it now. If I were getting disconnects every two or three days, I would not be happy.
Note: I think WRT54G is correct. We're on the road now, so I can't look to make sure.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
sch911
Rochester Hills, MI
Posted: 07/05/08 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Need more info.... Is this a wireless router? What type of WAN (Internet) connection is it using (DSL/CABLE/OTHER)? In general if you see your neighbor connected to your router he is stealing your bandwidth, do you have WiFI security setup on your router?
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
pulsar
Lewisville, NC
Posted: 07/05/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
The OP states that he finds himself connected to his neighbor's network, not the other way around.
Tom
RetiredBob
Portage, MI
Posted: 07/05/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
It's a D-Link DIR-615 wireless router. No, my neighbor is not using my network. Mine is protected. As noted above, I occassionally connect via my neighbor's (unprotected) network.
sch911
Rochester Hills, MI
Posted: 07/05/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
How does your router connect to the internet? Is it on a cable modem or DSL connection?
I'm struggling to understand how your router can connect to your neighbors network????
Or, perhaps do you find your computer/laptop occasionally connected to your neighbor's wireless router? This would make a lot more sense.....
Pepperoni
Ypsilanti, Michigan 48198
Posted: 07/05/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I would turn off the router ID broadcast (so you can't be seen) and change the DHCP start/end range. (to reduce number of connections and move the IP range.) With that done, I would change the router name and the password. (if left on "admin", any idiot can change your router settings) If your neighbor is showing on your DHCP client table with your machines, it means he is connecting to your router.
If you are actually connecting to your neighbor's router, there should be a way to remove that connection option, probably in your wireless card setup options.
* This post was edited 07/05/08 07:39am by Pepperoni *
Glenn And Kitty
Breaux Bridge, LA
Posted: 07/05/08 07:47am Link  |  Quote  |  Print  |  Notify Moderator
I also have a router problem and I was just about to post a question when I saw this topic. My connection is dropping about every fifteen minutes to two hours. It started a few days ago.
I have a Westel 327W router and it is a DSL connection. It is for wired or wireless connection. The strange thing is that all my wireless connections (three computers) work fine. The only dropped connections are the hard wired units (two computers).
I had a phone company guy over here Thursday and he couldn't figure it out. I'm supposed to call Monday, if it's still dropping connection, and have them come back.
What I'm learning is that it may have something to do with the Server refreshing the IP address and a recent Microsoft update is conflicting with that. If this is for real, it may have something to do with the other 'connection" problems mentioned in this topic.
Every time my connection is dropped I have to disconnect the power to my router for about 15 seconds, plug the power back in, wait a few seconds, and them I'm re-connected to the Internet.
My on-line connection time has run from two hours to less than five minutes for the last week. Interesting is the fact that my computer does not have to be on to loose connection. I can turn my computer off after having been connected and come back an hour later, start it up, and it won't be connected. I get the "webpage not displayed". I do the router power down then up thing and then I'm connected.
That seems to tell me that it's not my puter. By the way, the phone company guy installed a new router on Friday so I'm pretty sure it not the router either. This makes me think it is a "Server source problem" and perhaps gives credibility to the "Server and Microsoft update conflict" I heard and read about.
Sorry for being long winded but this is complicated. If anyone has a solution, please post it. If I get a resolution on Monday when I have another "expert" from the phone company come by, I'll post it as it may help resolve the other issues in this post. Even though the dropped connection issues posted are not nearly as frequent as what I'm experiencing the fix I obtain, if any, may work for those also.
Glenn
* This post was last edited 07/05/08 08:08am by Glenn And Kitty *   View edit history
2006 Trail Sport 22QB
2006 F-250 Super Duty
 > Refreshing Router
