willise
Canada
Hi all,
Just starting tomorrow on our first (only)camping trip this year. The tires on my Jayco 254 say Maximum 50 PSI. They are currently at 40 PSI.
Should I inflate them all to the maximum? Will that improve towing? I've always been afraid of going to "maximums" LOL
Thanks!
BarneyS
S.E. Lower Michigan
I always run my trailer tires at the maximum stated on the sidewall of the tire. Have never had a tire problem (yet! Knock on wood!)
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
willise
Canada
Great!
Thanks again!
dbbls
Missouri
Always inflate them to the pressure posted on the sidewall. Check the temps when the tires are cold. Do not pull it any distance and then check.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Terryallan
NC
Tires only carry their max load at max air. Max air, also helps them to run cooler, and lower the chance of tire failure. Always run max air in the trailer tires. As mentioned. Air them cold.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
tvman44
Southwest Louisiana
By all means, before you leave. If you don't you are asking for problems.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
loufish
Burbank, CA
I agree, run max air...BUT since you asked, you should know why...
Just about every trailer delivered has tires that JUST meet the weight ratings, the manufactures don't put "too much" tires on..
In real life you adjust the air pressure to the load, very much like the tires on the TV. My truck has "D" range tires and at their max inflations just 2 of them could hold up my truck even when it's loaded...but since I have 4 tires I can run them below their max and still be safe unlike your trailer tires...
"I won't camp next to you, if you don't camp next to me!"
2004 Titan King Cab, 2wd, 5.6L V-8, 5 Speed Auto Trans, Tow Package.
2004 Jayco Qwest Baja P/U
2002 Honda XR650R
willise
Canada
Great information guys!
I will inflate all 4 tires to 50 PSI.
Thanks
SPRey
Orange County, Kalifornia
Equally as important are the tires on your TV. Those should be at the MAX as well--then after the towing, drop back down to the suggested inflation.
Tim & Sue
Gerry (GSD) & Jammer (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 37 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
Red Wine anyone?
loufish
Burbank, CA
Quote: Equally as important are the tires on your TV. Those should be at the MAX as well--then after the towing, drop back down to the suggested inflation.
That's too broad a statement...Has to do with tire load rating...Did you read my post about TV tires being rated way more then needed?
I choose my tires on size, I had no choice in rating, if so I could have went with a "C" rated tire and then I might need to max it out while fully loaded/towing....My "D" rated tires at max will hold a little over 12,000 lbs for a truck that has a GRWR of 6400 lbs...So I don't need to run mine at their rated max pressure to be safe...
You inflate to match your load, if it's close to the max rating of the tire, then sure max inflation will be no problem.
