I have a 2004 Prowler Regal 270FQS. The posted GVWR by Fleetwood for this camper is 8000lbs. The tires that it came with are ST205/75R/15C which have a load rating of 1820lbs per tire. 1820 x 4 = 7280. So if my camper were loaded to the max allowed by Fleetwood, the tires would be overloaded..right or wrong?
The current year model Fleetwoods with an 8000 GVWR now come with ST225/75/15D.
Jim is right but even then you are very marginal. Mfgs put the least expensive tire size on just to meet the specs. I would weigh your TT all loaded as you would normally have it. If you are running that close, as soon as practical, upgrade to d's or e's.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
I replaced mine with load range D's. I don't have them handy to check but seems like they were in the 2400# range, plus or minus a hundred for poor memory.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
A TT usually has 10-12% of the weight on the tongue so you are then okay but just barely. When time for tires move up to a higher weight rated tire.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!! MY TRUCK OUR TRAILER
