RV.Net Open Roads Forum: Tech Issues: water pipe smell
 > water pipe smell
GATJcampers
CA
Posted: 07/05/08 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I have a problem and need some ideas. When I open any cupboard that has a water pipe in it (under kitchen or bathroom sink ) i get a bad odor that smells like sewage or stagnant water. There are no water leaks and the pipes feel solid. My trailer is a 2008 toyhauler and has been out 6 or 7 times. The smell is strong enough to linger in the trailer for a couple minutes. Does anyone have an idea what this could be. Any help would be appreciated.
JFG
TN
Posted: 07/05/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
It's probably just stagnate water. The systems are vented and the smell is escaping from the vents. Fill both sinks full of hot water and some kind of soap or pinesol. open drain and it should flush anything hung in j traps down to holding tank. Pinesol or detergent will help deodorize the tank.
Fred
SieraSam
Gold Country
Posted: 07/05/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
What else do you have under that sink? Could be a wet rag that is decomposing? or some vessels with spoiling liquid exposed to the atmosphare?
Class A, FMCA #F269745
99damon
Colorado
Posted: 07/05/08 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Also, try to locate your air admittance valves, they are most likely at the top of the vertical pipe that the sink p-traps connect to, and then down to holding tanks. When sinks drain a vacuum is created that can suck the p-traps dry, allowing odor/gas to come up from the tanks. The AAV lets air in to relieve the vacuum, but if it sticks open, the gray tank odor has a straight shot to the coach.
I had gray tank odor under the sinks until I replaced the AAVs, and I promise you that gray odor can be worse than black odor. Just playing the odds, I think tank gas in plumbing cabinets is more likely than multiple fresh water plumbing leaks. Let us know...
Wayne
Fulltimers
1999 Damon Intruder 341
john b
anywhere USA!
Posted: 07/05/08 10:56am Link  |  Quote  |  Print  |  Notify Moderator
This is most likely your problem! They are most commonly called Vacuum breakers!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
GATJcampers
CA
Posted: 07/05/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I am definitely gonna check out those valves. Are they usually located inside the cabinet or under the coach? Does anyone know how you test these valves? Thanks for all the help!
Kirk
Livingston, Texas.
Posted: 07/05/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
The vacuum breakers are located on a stub of drain pipe that turns up under the sink and ends just below the bottom of it, inside of the cabinet. The device is just screwed on to the end of that drain pipe and replacements are available at either Home Depot or Lowe's. They will cost about $4 or so. When you put the new one on, coat the threads with a little Vaseline or similar product. It makes a better seal and the next time one is needed it will remove more easily.
Good travelin! ........Kirk
sent via Starband, Manual Flyer dish
www.adventure.1tree.net
GATJcampers
CA
Posted: 07/17/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I checked the vacum breakers on the pipes and they seem fine to me. I had to take the trailer in for some warranty work so i went ahead and had them check out the smell problem. Unfortunately they told me it was because the grey tank had smelly water in it and i need to flush more often and use chemicals. I flush after every trip, the only reason i didnt after this last trip was to investigate that smell. This repair shop is horrible and their explination doesn't make sense. Am i correct that you shouldn't be knocked over by smelly grey tank no matter how full it is? Specially considering the tank was only i use for a week. Am I correct or is this an incorrect assumption? anyone?
goingnorth
Petersburg, MI
Posted: 07/18/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Change the vaccuum breakers to the more expensive $25 ones at lowes the cheep ones don't always work, I went through several diff. cheap ones and they would "burp" the gray tank once in a while.
My jayco toy hauler has one sinks drain that must go halfway into the gray tank cause when the gray is half full and am taking a shower it will blow out the p-trap in that sink and not fill the tub.
So I had to run a second vent to the roof, I ran 1/2 copper tubing from just bellow the vaccuum breaker through the wall and up through the fridge vent to the roof. Its enough to relieve the pressure. Much easier than dropping the tank.
Also do not plug the vaccuum breaker because when your traveling it will suck the water out of the p-trap as air passes over the roof vent. thats one of the reasons for having the VB. Then it will vent into the trailer untill you use water, I tried plugging mine and found out the stinky way.
08 F350 FX4 CC SB 6.4L
(sold)99.5 F250 sc lb 3.73ls 4x4 100k
28' Jayco talon zx toy hauler 10,000# w/o toy's, tongue wt 1600# Titan Tow Beast wd hitch Dual Cam
22' Renagade 3place snowmobile trailer 2000# w/o toy,s
Clay L
Sioux Falls, South Dakota
Posted: 07/18/08 09:21am Link  |  Quote  |  Print  |  Notify Moderator
GATJcampers wrote:
I checked the vacum breakers on the pipes and they seem fine to me. . Am i correct that you shouldn't be knocked over by smelly grey tank no matter how full it is? Specially considering the tank was only i use for a week. Am I correct or is this an incorrect assumption? anyone?
You are absolutely correct. It's a sealed system other than the roof vent and if everything is working right there should no odor.
I don't think you can tell how the air admittance/vacuum breakers are working by looking at them. There is a internal flap that is supposed to close and seal and I don't think it's visible from the outside.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
 > water pipe smell
