RV.Net Open Roads Forum: General RVing Issues: generator fuel tanks
 > generator fuel tanks
houhjc
at the pump, tx
Posted: 07/05/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
anyone have any good stories or pics of home made extended run fuel tanks? preferbably for the honda 2000's? cant see paying big bucks for one when someone has made one that works just as good at half the cost!! thanks
2007 Ram 3500 6.7 DRW 4X4 6speed manual
2003 362bbs bunk house
firedude
On the road
Posted: 07/05/08 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Here ya go!
houhjc
at the pump, tx
Posted: 07/05/08 11:12am Link  |  Quote  |  Print  |  Notify Moderator
i actually came across that while searching on the web for these tanks. i posted here to see what other options were available. do you think i could run 2 2000's off of one feed hose such as yours, or would you recomend two seperate tanks, one per generator.
like your set up.
firedude
On the road
Posted: 07/05/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
like your set up.
All ya need is a "T" in the line from the tank and then a line running to each genny, so yep, it works.
2 tanks is a bit much in my opinion and the only thing gained would be longer run times with the 2 generators is all. happy searching and good luck!
houhjc
at the pump, tx
Posted: 07/07/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
what size fuel line are you using to connect the extra tank to the generator fuel cap?
