jparker66
Rockwall, Texas
Where do you put your water filter? I put mine on a 90 degree so it will hang straight down, then I hook the water hose to the other end of the filter.
JP
James & Sharon
2006 Holiday Rambler Savoy SL 29'
2004 Dodge Quad Cab Hemi
CAMPING IS GREAT! ENJOY THE OUTDOORS!
javaseuf
California's Gold Coast
Mine is under the kitchen sink. I felt no need to filter all of the incomong water, just the drinking water.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
PapPappy
Wilmington, NC
We're doing it at both the incoming line, and at the faucet on the kitchen sink. Figured we'd like it at least pre-filtered when we brush out teeth!! I just get one of those in-line hose filters and attach it at the end of the hose....hope that it lasts for a season??
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
BaldyD1
Central Florida area
Recommend filtering all incoming H2O so ice maker makes good ice.
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
BillB800si
S.E. MICHIGAN
Here's the filter we use for the whole trailer.
Water Filter with bracket
Notice it has a mounting bracket that's available seperate. We use the carbon filters and change them twice a year.
We still only use bottled water for drinking. Not just for pure water but for taste.
Happy trails,
Bill B. (Michigan)
2007 Dodge Ram 2500 MegaCab CTD
2007 Jayco Eagle TT Model 322FKS
NCHornet1
Mt. Airy, NC.
I also use a whole house filter that is at the inlet hose on the ground, but I bring bottled water for drinking, go figure!!
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Dick_B
Palos Heights, IL USA
Our filter lays on the ground and a short piece of hose connects it to the camper. This takes the weight of the filter off the inlet connection.
But, actually, we hardly ever hook up but rather fill the Freshwater tank and rely on the pump for water. Bottled water for drinking and coffee.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
arasgrandpa
WA (Summer) AZ (Winter)
Here's mine. I modified a whole house filter from HD to use hose on both sides. Connected some brass quick disconnects and used a 4" piece of PVC drain pipe to make the holder, works great for me. Plus I can use either a charcoal filter element or the bacteria destroying filter element, although I may go to a two stage and use one of each.
Arasgrandpa (47)
Arasrana (46)
2001 F150 SCrew (Gotts Mod)
2008 Trail Cruiser TC23SB
http://lotsastuff.tommymartin.info
jparker66
Rockwall, Texas
Tom,
Do you keep the filter permanently on the bumper? What is "HD?"
Thanks,
James
browns329
New Jersey
jparker66 wrote: Tom,
Good question! How is the 4" PVC mounted? That gives me another idea...I could use a piece of PVC and just stake it in the ground. Then again, Rick at RVwaterfilterstore.com said that the carbon block filter that I have will work just fine laying on its side.
What is "HD?"
I believe it is Home Depot.
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
