flrvman
Southeast
Hi all, I have had this coach 3 years. NEVER A SMELL BEFORE. Parked on private site w/septic tank. Have always left gray tank open without a problem. But here I can't. Oders come up quickly if I do. Have to leave gray tank closed. Any ideas? Yes black tank is always closed. I usually fill gray when black is nearing time to empty to wash out hose. Thanks ahead of time for any help. Other than keeping grey closed which I am doing.
2003 Revolution 40C
Taupe/350 Cummins/
toad-2005 Chevy Malibu - Gold
Florida/full-timers
flrvman
Southeast
Oh yes, I have replaced vent on drain line.
driveby
Vancouver BC Canada
If it is the site sewer, probably not much you can do. if it is your grey tank - dump some chemicals in and fill and let them do their thing.
Otherwise, just dump once a day and leave it closed.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
stevelv
FullTimers at Last!
Firstly, your own gray water will smell after 48 hours and secondly, the sinks etc all have P traps to prevent odours inside the RV - the only smell should come through the roof vent which is open to the air.
So are you smelling sewer smells inside the RV? You want to disinfect the gray tank and your P traps.
If I have the time, after dumping, I'll fill the gray tank with fresh water and a small amount of bleach or pine sol and leave it for 30 minutes and then dump that. Cleans the gray tank and the sewer hose.
RV Park Finder
Fulltimers
2002 Beaver Santiam 38DST + Banks + 99 Jeep GC
DH,DW,Jake and Indie
chastho
arkansas
Maybe time to change the vaacum breaker under the kitchen sink?
hershey
Albuquerque,(fulltime) NM, USA
I added the vane attachment to the top of my gray vent about 3 years ago and have not had a problem with odor since.....any yeah, we don't use chemicals either.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
maxmorrow
Birmingham ala.
The gray tank can smell almost as bad as black tank. As another post said check vents on top and under the sink. We were getting bad odors from ours and I found a dirt dauber nest had stopped up the vent on top. And yes the vane type vents do help... John M.
If you ain't the lead dog...the scenery never changes!!!!
Clay L
Sioux Falls, South Dakota
chastho wrote: Maybe time to change the vaacum breaker under the kitchen sink?
That would be something I would check for sure. There may also be one under the bathroom sink. There is on mine.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Tinstar
McKinney, TX
I have vacuum breakers under both sinks. You shouldn't have any odor if all is working properly.
Never pass up a chance to go somewhere
SGTJOE
Utah
Other then a RV store are these vacuum breakers available at Lowes or Home Depot??
2001 Trade Winds 7390
Toad 03 Grand Am
